I want to refresh form which is calling through a class.User is selecting records on form and then deleting them. I used cache remove record method for same but it is working only for first record. how can i achieve this for every records which user selects. Kindly suggest.
It doesn’t matter how you are calling the form. The form will be refreshed automatically after deleting the records (using the delete button).
Please explain it clearly, if your requirement is different.
Moving to developer forum.
I have given a button on form which updates data and there are some code on class which has to be recalled when data is updated because i want the form to be refreshed again and data should be removed from that form without opening the form again. How can i achieve this?
