Refill picking locations
Hello,
I have dynamics ax 2009 with WMS1 . Is there a way, f.e. in Master planning, to propose inventory refills of picking locations?
Kind regards,
If you set your dimension group up with item coverage at the location level you could theoretically achieve this I suppose, I would not recommend it however, it is planning at location not warehouse level, WMSII is used to refill picking locations. Not sure it is possible to configure at this level, turn it on and see.
