Hi everybody. I’m creating an Excel sheet, and I must cycle over the records of a navision table and for each record insert a value in a cell. The problem is that for each record I must increment the column of the cell and not the raw (so for example: firse record does in cell A1, the second one in B1 and so on). I would like to know if it is possible to reference the Excel cell with raw and column without using the letters! I tried the property Cell but it does not have arguments in the Automation Controller. Thanks in advance Marco
Ciao Marco, Report 29 or 82 will show you how export to excel works. /Karl
