Hi There, Well I have this strange problem after making a backup of navision attain 3.6 sql version and after restoring the data into the new database, when click on sales and receivables, posted invoices, I get the message “Reference to the Member No. of months of the variable could not be solved”. I have no clue as what went wrong or how could I correct this. Any guesses from anyone’s. Please its very urgent. Best Regards Khan\
This means this field is not in the database table but is placed on the form. Try to design the Posted invoice form and the compiler will point to you the control that contains the error. The problem can also exist in the subform. You can also compare the forms and tables in both databases. Regards, Mark
Hi Mark, Found out the problem was coming from where after your suggestion of choosing compile to check the error. Thanks Mate. Regards Khan\
