I just got a new license Yesterday, I was using an old license to develop a solution on SQL server. My Server keep on loading the old license even though I have deleted it from the server. I have tried Re-installing the server with the new license, it boiled down to the same thing. Adewale A. Abiola
quote:
Originally posted by dewaliii: I just got a new license Yesterday, I was using an old license to develop a solution on SQL server. My Server keep on loading the old license even though I have deleted it from the server. I have tried Re-installing the server with the new license, it boiled down to the same thing. Adewale A. Abiola
Hi! With Enterprise Manager delete table $ndo$srvproperty from master database. Next time when you open your database, you will be asked to locate your flf file. regards Bostjan
Navision Financials License File on SQL Server 7.0 Question Where do I find the Navision Financials License File on the SQL Server? Answer The license information is saved in the master database in a table called $ndo$srvproperty. If this table is deleted, you will be asked to upload a new license file the first time you connect a Navision Financials client.
Or, to avoid external tools, from Financials use Tools/License Information/Upload to upload your new license file to the server.
I Now understand the steps,Using SQL and Navision. I have used Navision option since it is simpler. First, I Change to new license, then I uploaded. Thanks so much for your contribution, U made my day. Regards Adewale A. Abiola
