Does anybody has Redmoon Fixed Asset data import into Navision experience ? we used Redmoon For SAP B1, but now we change to Navision. so I need somebody help.
Are you going to use Navision Fixed Asset Module ?
If yes then you need to export data from Redmoon and prepare the data in Navision Fixed Asset format and import it using XMLPort.
Amol,
Thanks a lot, I know I can use XMLPort to import RedMoon data into Navision, but I want somebody has the template with RedMoon.
so I can use this template to import data and I don’t need to think about how to get correct data to match Navision from RedMoon.
