Recruitment Status "Completed" ??
In Human Resource---->Recruitment Project Details ----->Application Details In this “Application Details” form when an applicant status is changed as “Employed”, i want the corresponding record’s “Status” in the “Recruitment Project Details” form as “Completed”.
Means you want to change the status of the recruitment project automatically based on the status of application details.
For that you need to check the all applications details and their status - when you changing the status of each application to employed. If status of all the applications are found as Employed during search then update status of the recruitment project.
for that you need to put your code in class HRMEmployeeEmploy. try to debugging the code for - where to write the code…
In HRMEmployeeEmploy class, “Run” method the condition has to be specified to automatically change the status as “Completed”
