Recover itemId using name alias in an extended data type that don't belongs to a table
I don’t know if someone has come accross the same problem. I’m using an extended data type that extends from Itemid in a form. This extended doesn’t belong to a table. So when you put the name alias in this field instead of recovering the Item Code as happens in any table it left the name alias.
It seems that the search of the item code when you put the name alias only works if the field belong to a table.
Thanks in advance,
RL
