Hi
When I am trying to open Sales packing slip report in AX 2012 , am getting the following error : “RecordId” parameter is missing a value.
Can anyone help me out please…
Regards
Sindhu
Hi
Regards
Sindhu
If you are opening from VS then you will get this error because you have provide RecId.
No I am opening it from AX client itself.Then too I am facing this issue…
Is it standard report or you have customized the standard report??
I have customized the standard report.I have added one field to the temporary table and added it to the design.
First removed the field which you added in report and then checked whether you are getting same error. If not then there is some problem in field only.
