Record Parameter in function lost filters?
Hi Expert.
recently, When I am design a report, I found a strange problem, Maybe I have misunderstand of the point.
I.E.
NAV2016.
FUNCTION CALL:
G_WhseEntry.RESET;
G_WhseEntry.SETCURRENTKEY(“Item No.”,“Bin Code”,“Location Code”,“Variant Code”,“Registering Date”);
G_WhseEntry.SETRANGE(“Bin Code”,“Bin Code”);
G_WhseEntry.SETRANGE(“Lot No.”,G_WhseEntry_lot.“Lot No.”);
G_WhseEntry.SETRANGE(“Location Code”,“Location Code”);
G_WhseEntry.SETRANGE(“Item No.”,G_Item.“No.”);
G_WhseEntry.SETFILTER(“Registering Date”,’%1…%2’,StartingDate,EndingDate);
G_WhseEntry.SETFILTER(“Source Document”,’%1|%2|%3’,G_WhseEntry.“Source Document”::“Phys. Invt. Jnl.”,G_WhseEntry.“Source Document”::“Item Jnl.”,G_WhseEntry.“Source Document”::“Reclass. Jnl.”);
//G_WhseEntry.SETRANGE(“Entry Type”,G_WhseEntry.“Entry Type”::“Negative Adjmt.”);
G_WhseEntry.SETFILTER(“Qty. (Base)”,’<0’);
QtckQTY := CalcWhseQty(G_WhseEntry,G_UOM,G_Item.“No.”);
Temp_Data.num7 := QtckQTY;
FUNCTION:
LOCAL CalcWhseQty( L_WhseEntry : Record “Warehouse Entry”;L_ToUom : Code[50];L_ItemNo : Code[50]) : Decimal
//IF I ADD VAR FOR L_WHseEntry, we can get filter from the parameter, else it doesn’t.
L_QTY := 0;
ERROR(L_WhseEntry.GETFILTERS); // HERE IS EMPTY
IF L_WhseEntry.FIND(’-’) THEN
REPEAT
L_QTY := L_QTY + L_WhseEntry.Quantity;//
UNTIL L_WhseEntry.NEXT = 0;
L_QTY := GetQTY(L_WhseEntry.“Unit of Measure Code”,L_ToUom,L_ItemNo,L_QTY);
EXIT(L_QTY);
if what I understand is correct?
Hi Gary,
Try with a VAR in the L_WhseEntry parameter.
Yes ,VAR in the L_WhseEntry parameter is ok, I just don’t know the reason why i pass the NONE-VAR parameter can not pass its filter?
