record level security.....
  1. the user who logged in the ax should see his record only,not others.
  2. But his manager can see his records as well as his other repotee record also.
How to do the setup in security level.i checked some docs,but didn’t get the clear picture.
Hi, Configure User group permissions under Security Setup of Administrator module.
Thanks.
Hi Shashank,
If you want to show the some range of records to the users U can do RecordLevel Security.
Administration → setup->Security → Record Level Security.
Hi I am also looking same thing but my case is own customized form and tables…
Customized new table is not appearing in the record level security. How can get it customized table in the record level security.
Thank you
Regards
Shankar
Do you have attached security key to your customized tables…
Hi…all,
I have one combo bax with some values… when i select on value based on that value records should diplaying first time bt here refresh
problem is coming like when i select the another record in combo box it will not displaying in secong time… how it over come?
Hi Ramesh
U can get this resolved .
Go thru–ledgerjournaltable form- Show- combobox with All,open,posted options–Methods
The records changes accordingly–!!
basically its like- override the execiute query method of data source and call it in the combobox-methods – form level
HI Ramesh,
Do you find any difficulty in adding your problems as new posts rather than continuing the some one posts?
Because it create a confusion to the original poster.
Let us know if you are finding any difficulty in doing that.
