Hi Friends,
We are aware Record id is always unique in Axapta.
I have a question, If there are one lakh records in my database and if i deleted 100 records will be my deleted RecordId
will be reused for other newly created records.
Reason for the Question: I am developing some registration functionality in Axapta. A new record is getting created when ever i split lines. I doubt whether I can used Max(RecId) function.
No, they deleted RecIds won’t be reused.
You didn’t tell us what you’re trying to achieve with Max(RecId), but most likely you shouldn’t do that.
So, if the total capacity of database is 1 crore records and if all 10 digit Recid increment is completed then later i decided to delete 1 lakh records the how will the RecId will increment. Just a logical question.
No, the range of RecIds is 2^64 (in AX4+), a croce is mere 10^7.
That you delete something has no impact to the sequence. If you used had 10^7 IDs, the next one will be 10^7+1 or something close to that (it’s actually more complicated, because IDs are allocated in batches and you may have several application servers).
