Recalculation in AX 2009
In AX 2009, when we run recalculation for item/item group it checks for financial dimensions, i would ike to
know which all tables are being checked ?
Or in other words, can some one suggest, which all tables to be checked to make sure that financial dimensions are not left blank.
Thanks in advance.
All suggestions/thought will be handy.
check your InventDim table. if there were records with empty dimensions, try to run the periodic cleanup job in Inventory management>periodic>cleanup>inventory dimensions cleanup.
if still the recalculation did not execute, then it is a problem with your dimension group configuration, especially if u have the MultiSite functionality activated.
