I am using NAV 3.7 to execute a stored procedure residing on sql server 2000.
When I tried to run the report, the error:
This message is for C/AL programmers:
An exception was raised in method Append. The OLE control or Automation server has returned error (HRESULT) -2147352567. The component did not provide the exception description.
lADOParameter:=lADOCommand.CreateParameter(’@TemplateID’, 200, 1, 20, vTemplateid);
lADOCommand.Parameters.Append(lADOParameter); ← Error occurs here
Appreciate it if someone could help.
