Reading Data through SQL Data Reader in AX 2009
I am using the following code in AX 2009 to read the data, fetched from database and want to assign it to a variable but i am not able to do so…
Please anybody can help me beacuse it will help me to complete my task.
I need help on the bold text.
static void CheckDatabaseConThroughDotNet(Args _args)
System.Data.SqlClient.SqlConnection con;
System.Data.SqlClient.SqlCommand com;
System.Data.SqlClient.SqlDataAdapter da;
System.Data.SqlClient.SqlDataReader dr;
System.Data.DataSet ds;
str _vendName;
try
con = new System.Data.SqlClient.SqlConnection(strfmt(“Data Source=Ibrahim; Initial Catalog=DynamicsAx; Integrated Security=true”));
com = new System.Data.SqlClient.SqlCommand(“Select * from VendTable”,con);
con.Open();
dr = com.ExecuteReader();
while(dr.Read())
// _vendName = dr[0];
con.Close();
Catch(Exception::Error)
info(“error in Error Class”);
Catch(Exception::CLRError)
info(CLRInterop::getLastException().ToString());
I got the solution ,
while(dr.Read())
box::info(dr.get_Item(0));
