Need a help on how to extend AX 2009 to read and write message(xml) from IBM MQ.
If someone have experienced on reading and writing messages to IBM MQ, need their expert help…
Welcome to DUG [:D]
I have not worked on integration with IBM WebSphere. But since you mentioned XML, have you looked at AIF in DAX? AIF is the recommended for XML integration path.
