read the xml file with namespace in navision 2015
hii,
how to read the xml file with namespace in navision 2015.
i want to read the order date,item no.,description from xml file…
but xml fie is designed with namespace…i want to read the attribute by element of xml file…
kindly give me the solution…
I can suggest you to make use of Codeunit 6224.
Refer this below link, it might be helpful for you.
moxie4nav.wordpress.com/…/
i can not find the solution …can you give me some another solution…how to use it?
Why you want to reas with Namespaces???
Remove namespace it will become easier for you.
rockwithnav.wordpress.com/…/
