ReAcive Or Reopen Form In Dynamics Ax
hi all
i Change User Default Setting By code In form, Now I Want To Close And Reopen Form To Refresh Form in same form
I Use Dataset_Ds.refresh() , Reread , element.Refresh , reread , research , …
but Does not work correctly
Please advise if you have a solution to this problem
thanks all
use this , if you have a button for refresh , write it on clicked method on that button. should work
Datasource_ds.research(true);
Datasource_ds.refresh();
check out this link
http://supplychaindynamicsax.com/how-to-auto-refresh-form-data-in-microsoft-dynamics-ax/
hi abhijit
thanks for help
but this is not Solution
Did you ever find a solution?
The original question itself was not clear? You can explain your problem in a separate thread.
