RE- get value from one field and store into another field
Hi All
In salesOrderCreate Form, i created the ALE_SampleDistribution check box. and i have created the ALE_SampleDistributionAccount field in the custparamenter.
salesordercreate form having the custaccount field. if ALE_SampleDistribution check box is checked, custaccount field fetch value from the ALE_SampleDistributionAccount field in the custparamenter
i wrote coding in the salesordercreate datasoruce-- ALE_SampleDistribution check box(modified)
public void modified()
CustParameters custParameters;
CustTable custTable;
super();
if(SalesTable.ALE_SampleDistribution == noyes::Yes)
SalesTable.CustAccount = custParameters.ALE_SampleDistributionAccount;
else
SalesTable.CustAccount = custTable.AccountNum;
but it’s not working
any one help me
Hi Smiley,
The thing it is not passing the ALE_SampleDistributionAccount is it is not selecting the record from the CustParameters…
try to use below in the above code…
custParameters = CustParameters::find();
or
SalesTable.CustAccount = CustParameters::find().ALE_SampleDistributionAccount;
it’s working naresh…
thanks ya
