re:files creating
can we create a text file throu c\al code
Do you mean export out a report to excel using C\AL
look at outstream
http://msdn.microsoft.com/en-us/library/dd301078.aspx
has sample code
i eant to create the text file using c\al code ,and at the same time i want to get customer name and no in that text file .
please give an solution for this how to solve this
You can try something like this
// File1 is File object
// OutStreamObj is OutStream object
File1.CREATE( ‘C:\Output.txt’);
File1.CREATEOUTSTREAM(OutStreamObj);
OutStreamObj.WRITETEXT (‘First line of text that you want to write to text file’);
OutStreamObj.WRITETEXT (‘This is not the second line of text to be outputed but to concatenate with the first line’);
OutStreamObj.WRITETEXT(); // This command is to move to next line
OutStreamObj.WRITETEXT(‘Second line will start here’) ;
File1.Close; // To end the writing and write out to the file.
thank you amol…
i got solution .
Welcome!!!
how can we Hide Blocked items in Lists, reports and lookups?
