I create one columng in Bank account with varchar(50) and want to add the same in bank account form, I added the column but it didnt get save. in the database
There is something wrong here! You don’t create columns in Bank Account of the type varchar(50). You can create a field (NAV term) of the type code or text or some else.
If you added it to the form and saved the form again did you use the Object Designer for Forms? And if you did, did it go away when you open the form again - still from the object designer? If it didn’t then try to run the form directly from the object designer.
i DONT WONT TO RUN IT FROM OBJECT DESIGNER, CAN U PLS HELP ME HOW I WILL CREATE ONE COLUMN ON THE FORM AND IT WILL DISPLAY FROM THERE ITSELF…
Please do the need full
Hi Sonali
Create it in its source table and attached with form
