Rapport designer
Hi Does anyone know if there is a limit to the lenght of a rapport (or the length the rapport designer can show)? Im in a situation where i cant scroll futher down in the designer even it still accepts that i add a new section…just cant see and design it. John
quote:
Hi, John. Yes, there is a limit. I experienced a similar problem on a report some time ago. The report worked nicely, but I could not modify the last sections in the report designer. If I needed to, I had to export it on text file, modify the text and try to import it back, while crossing my fingers against the thousands of mistakes I might have done without the editor assistance. [xx(] After a while, I redesigned the report in a different way and now I feel much better! [:D] Anna
