Ranges
Hi.
public void init()
QueryBuildDatasource PurchLineDS, PurchTableDS;
super();
PurchLineDS = PurchLine_ds.query().dataSourceNo(1);
zakres1 = PurchLineDS.addRange(fieldnum(PurchLine, ItemId));
PurchTableDS = PurchTable_ds.query().dataSourceTable(tablenum(PurchTable));
zakres = PurchTableDS.addRange(fieldnum(PurchTable, PurchId));
public void executeQuery()
super();
zakres1.value(queryValue(inventTable.ItemId));
info(purchTable.PurchId);
I have 3 grids: InventTable, Purchtable, PurchLine. I mark in InventTable record and I have the PurchLineDS query build.
And I want to Have field PurchId joined with field PurchId from PurchTableDS.Do You have any ideas how to do it??
How are the data sources (InventTableDs and PurchTableDs) linked? I would set PurchTableDs is set as the child data source of InventTableDs and LinkType is Delayed. If there is a relation between these tables, it should work without any code at all.
There are no relation between those tables. So i must get together Inventtable PurchLine and PurchTable, because there is a relation InventTable.ItemId==PurchLineItemId and PurchLine.PurchId == Purchtable.PurchId. I don know how to connect them
You haven’t answered my question, therefore I can’t be more specific than this:
Try follwing code . i hope that it’ll resolve your issue .
QueryBuildDatasource QBDSInventtable,QBDSPurchLine,QBDSPurchTable;
QBDSInventtable =q.addDataSource(tablenum(InventTable));
QBDSPurchLine = QBDSInventtable.addDataSource(tablenum(PurchLine));
QBDSPurchLine.relations(false);
QBDSPurchLine.addLink(fieldnum(InventTable,ItemId),fieldnum(PurchLine,ItemId));
QBDSPurchLine.joinMode(joinmode::ExistsJoin);
QBDSPurchTable = QBDSPurchLine.addDataSource(tablenum(PurchTable));
QBDSPurchTable.addLink(fieldnum(PurchTable,PurchId),fieldnum(PurchLine,PurchId));
QBDSPurchLine.addRange(fieldnum(InventTable,ItemId)).value(queryvalue(InventTable.ItemId));
super();
Don’t forget to verfied Solution
