Range lookup like SysQueryForm need on bound control
I have requirement where lookup should work like standard query form. Previous value of lookup should remain as it as and new lookup value should be added to it
e.g. if we have lookup for customer accounts on customized form control , it should allow us to add value like “ABC01…ABC12”
Thanks in advance
You can use ReplaceOnLookup property if u are doing the operations in form controls… Set it to No.
Thanks Chaitanya…!! its working :slight_smile:
