range in where clause
hi Friends,
is it possible to add range in where clause , like this:
Select sum(AmountMSTSecond) from TurnoverCost where
TurnoverCost.AccountNum == ‘700000…7100000’
TurnoverCost.Dimension[4] == _Resno &&
TurnoverCost.TransDate >= FirstDate &&
TurnoverCost.TransDate <= TodayDate;
or any alternative
You can’t use “…” operator in X++ queries (you can if you rewrite it to the Query framework). You’re already using the right approach with the TransDate field.
