Hello, Does anyone know how to extract the first and last item from a range entered through the query of a report, f.i. itemid : xx.xx.xxxx…yy.yy.yyyy Range(fieldnum(table,tablefield)).value() == xx.xx.xxxx…yy.yy.yyyy Can I extract the numbers xx.xx.xxxx and yy.yy.yyyy from the range or am I obligated to use substrings? thx in advance, Kathleen
Hi To my knowledge, there is no parser available, so you’ll have to use string commands.
What are the string commands that are available for parsing? Are there some commands like SubString? For extracting a string from another? And something like StrPos for determining position of one string within the other?
Hi Bojan, You can see the list of functions at AOT → System Documentation → Functions. Take a look at functions prefixed with “str”… and yes… there is a subStr function as well. Cheers
10x Chee Kang, I have also found some of them under AOT->Classes->Global. They have worked ok.
