Random Cheque no. selection......
I am generating the cheque from AP>Function>Generate Payments…but the Cheque no. is sequential in the same …Can we generate the Random Cheque no. there…
Jinesh Shah
If the check is single, you can select check number from the dropdown. User can select any check number.
If there are multiple vouchers, system will generate the checks in sequence. User can only select the first check number.
Pranav…
