radio button and hiding group
let suppose i have login and sign up and there are 2 group g1 and g2 if i am using login then g1 will be visible and g2 will be invisible and vice versa
can anyone tell how can i do it please ?
public boolean validate()
boolean ret;
ret = super();
switch(LogDetails.selection())
case (0) :
LoginDetails.visible(true);
EveryDetails.visible(false);
case (1):
LoginDetails.visible(false);
EveryDetails.visible(true);
return ret;
i used this
And both of the control(Logindetails & Signupdetails) should be initially set as visible false.you can do this in deisgn.
it is not working
only one group is showing
can you tell me whether my coding is correct or not
