Hello !
HI ,
I have the default 3 FinancialTag Vales (for 3 main dim which are cost center, dept. and purpose) from an external system, but how can i set those values for example in inventJournaltrans item ? Those 3 values should give me a REC ID where i can put into the defaultDimension property in inventjournatrans item.
I have seen many post on the opposite scenario but not for this!
Thanks and hope some one can help me
Cheers —
Kumar
