Question about Navision SP2 Relationship Management (CRM)
Hi Forum,
Navision Relationship Management Interactions uses Word as the email editor but can you attach Pdf’s and Excel Spreadsheet to the Outgoing email as an attachment to the email.
Is this possible, if so can someone please explain how. Thanks Paul
Hi Paul
I believe you can use the import funciton to import any kind of file, then set the interaction to email and when you go through the interaction it will add the attacment to the email.
Hi Steve, good to hear from you again, I will pass this information on. Many thanks as usual. Paul [:D]
