i am trying to use this method
to sort the results .
for example
QueryBuildDataSource qbds = qr.query().addDataSource(tableNum(CustTable));
qbds.addGroupByField(fieldnum(CustTable,Country));
is good.
Problem
i have a reference column in CustTable refers to another table lets say County
and i County Table recid is in CustTable.
i need to sort the results on actual value of CountyTable not on the reference column inside CustTable ie. County
----- answer could be add County Table as data source .
without adding County Table to the query.
is that possible?
