Query x++ with Dimension
Hi, all.
Help me, please
Axapta 4.0
Me need build query by using QueryBuildDataSource
SQL Query - Select * from Claim where Dimension4_ <> ‘KZR’ and Dimension4_ <> ‘EU’ ) and T_RepairId=‘ЗР033586’
I tried a variety of ways, but unfortunately they do not work
qbds = Query.addDataSource(tablenum(Claim));
qbds.addRange(fieldNum(Claim,T_RepairId)).value(sysQuery::value(“ЗР033586”));
qbr = qbds.addRange(fieldId2Ext(fieldNum(Claim,Dimension),4));
qbr.value(strFmt(’((%1.%2 != “%4”) && (%1.%3 != “%5”))’,
qbds.name(),
fieldid2name(tablenum(Claim), fieldid2ext(fieldnum(Claim,Dimension), Dimensions::code2ArrayIdx(SysDimension::Purpose))),
“KZR”,
“EU”));
Result -
SELECT * FROM Claim WHERE ((T_RepairId = N’ЗР033586’)) AND ((((Claim_1.Dimension[4] != “KZR”) && (Claim_1.Dimension[4] != “EU”))))
Error extended range query: expected right parenthesis next to the 27.
qbr.value(strFmt(’((Dimension[4] != %1) && (Dimension[4] != “%2”))’,
“KZR”,
“EU”));
Result -
SELECT * FROM Claim WHERE ((T_RepairId = N’ЗР033586’)) AND ((((Dimension[4] != “KZR”) && (Dimension[4] != “EU”))))
Error extended range query: expected right parenthesis next to the 14
qbr.value(strFmt(’((Dimension4_ != “%1”) && (Dimension4_ != %2"))’,
“KZR”,
“EU”));
Result
SELECT * FROM Claim WHERE ((T_RepairId = N’ЗР033586’)) AND ((((Dimension4_ != “KZR”) && (Dimension4_ != “EU”))))
Error extended range query: .
qbr.value(strFmt(’((Claim.Dimension4_ != “%1”) && (Claim.Dimension4_ != “%2”))’,
“KZR”,
“EU”));
Result
SELECT * FROM Claim WHERE ((T_RepairId = N’ЗР033586’)) AND ((((Claim.Dimension4_ != “KZR”) && (Claim.Dimension4_ != “EU”))))
Error extended range query: Claim.Dimension4_ is not correct pair datasource.field near 29
qbr.value(strFmt(’((%1.Dimension4_ != “%2”) && (%1.Dimension4_ != “%3”))’,tableid2name(tablenum(Claim)),
“KZR”, “EU”));
Result -
qbr.value(strFmt(’((%1.Dimension[4] != “%2”) && (%1.Dimension[4] != “%3”))’,tableid2name(tablenum(Claim)),
“KZR”, “EU”));
Result -
SELECT * FROM Claim WHERE ((T_RepairId = N’ЗР033586’)) AND ((((Claim.Dimension[4] != “KZR”) && (Claim.Dimension[4] != “EU”))))
Error extended range query: Claim.Dimension is not correct pair datasource.field near 25.
qbr.value(strFmt(’((%1 != “%3”) && (%2 != “%4”))’,
SysDictTable::fieldnameSQL(tablenum(Claim), fieldid2ext(fieldnum(Claim, Dimension), 4), FieldNameGenerationMode::FieldList), SysDictTable::fieldnameSQL(tablenum(Claim
“KZR”, “EU”));
Result - SELECT * FROM Claim WHERE ((T_RepairId = N’ЗР033586’)) AND ((((DIMENSION4_ != “KZR”) && (DIMENSION4_ != “EU”))))
Error extended range request
Hello,
i dint go thru with your all cases but i think you will find your answer here ,
post is of 2009 but you will get idea from it.
