Query Ranges can be set to Edit Format
Dear All,
Greetings for the day…
I just wanted to know that whether we can set the query ranges to editable format as per the attached screen.2656.point16.png
Users don’t want to go for the select, Directly he will paste the values and run the reports…
Thanks in Advance
Regards
Shreedhara
No, these fields in dialog forms can’t be edited - they merely display ranges defined in the specialized form that knows how to find available tables and fields, how to display lookups etc.
You can, though, create a new field in the dialog (as you already have From date, for instance) and then set the value of the field to a query range (in code).
