Hi I am new to Dynamics Nav.
Just wondering is there any way i can schedule a report in Navision to work for certain defined period only.
Once it exceeds the defined period it should not generate any data…
Ashly
Ashly
You want to run the report for a particular period or you want the report to automatically run for a defined time interval
Report should automatically run for a defined interval. There after it should not get generated.
Ashly
Then you can use the automation server , ‘Navision Timer 1.0’.Timer. Through which you can define your time interval in m.sec.
You can write your code which you want to execute automatically. Follow this link. You will get an idea how to use this timer.
Hi
I tried to follow the link but i get an error "
Requested URL: /forums/t/42141.aspx.
This url works for me.
http://dynamicsuser.net/forums/t/42141.aspx . You should have used the url without dot at the end.
