Query on form and Temporary table
Hello.
I have Temporary table (the outer table : tmpTable1), which link Table2 (the inner table).
I have created a query class (join), that I join the two tables.
I put the query on the form.
  1. When should I create data on the temporary table (on init method of the form?) ?
  2. I see that there are links nodes on any of the datasources, and I can see that the default is none - When and how should I change the links node in order them not be “None” as default, to see data on my form?
Need sample, please.
Thanks :slight_smile:
In Init method of the form, use the tmpTable.setTmpData method to set the data which will show the records.
  1. When using setTmpData, I get the message “Are you sure you want to delete this record?” - Why?
  2. I didn’t understand about the solution as I have asked on this thread about links nodes, and why is linktype = none.
http://learnax.blogspot.com/2010/01/how-to-use-temporary-table-in-form.html
check above link for example for form with temporary table
Problems :
  1. I want to have two datasource : One for temp table data, and second for a linked table.
Both table are on the grid of the form.
After I populate data into the temp table (on linkActive method), I see only the temporary table on the grid - What may be the cause.
The second table : linked type “delayed”, or “active” are incorrect. Even I have tried to change it from passive into active in code, just after the “linkActive” method of the temp table.
