I found below message in the NAV financial Manu of chapter 1: Financial Management setup.
“The system automatically creates the first two shortcut dimensions by using the Global Dimensions. The other six shortcut dimensions are available only if Advanced Dimensions are purchased.”
If we are Business Essentials (BE) user or Advanced Management (AM) user, is it required to purchase for this?
Advanced Management definitely contains the Advanced Dimensions.
For BE I’m not sure.
You should try to call your NAV partner in order to verify this.
I believe granule 4870 advanced dimensions is in the BE foundation package - you can check this by opening your license. The analysis view functionality to analyse the additional dimensions, I believe, needs to be purchased. It has been a long time since I looked at the licensing though.
