I’m receiving the below error message when i click amount fields in trial balance form after GST upgrade in AX2012R2.
QueryBuildRange object not initialized.
Stack trace
(C)\Forms\LedgerTransAccount\Methods\init - line 234
(C)\Classes\SysSetupFormRun\init - line 3
(C)\Classes\xMenuFunction\create
(C)\Forms\LedgerTrialBalanceListPage\Designs\DesignList\EndingBalance\Methods\jumpRef - line 10
(C)\Classes\FormRealControl\mouseDown
I tried compiling all the above objects. Also done full compilation, Full CIl and DB Sync. also tried deleting Xppl folder also. nothing helped.
Have you tried clearing your usage data and AUC files, sometimes when installing updates if the cache has the old version of an object it can cause errors like that, but it also could be something else…
Why it was set to Passive initially ? I can see in standard that the link type is set to ExistsJoin.
Have you done the compare? Also compare the init method of the form and see if some standard code is missing.
