Queries
I have a query and two datasources attached to it.Two datasources reference the same table.But both have different range values.
For Example:
Query has dataSources as CustTrans_1 and CustTrans_2.(Both reference CustTrans table)(Datasources are not joined).
CustTrans_1 has ranges as Approved = Yes and TransDate
CustTrans_2 has ranges as Approved = No and TransDate
Now I want to fetch the records which has (Approved status as ‘YES’ and TransDate <= 31-12-2011
) and
(records with Approved status as “No” and TransDate = 31-12-2012.)
Can Anyone help me on this please???
Regards
Sindhu
You need a Union query to add results of two queries together. Union queries are supported from version 2009, I think. Look at How to: Combine Data Sources in a Union Query [AX 2012].
If you’re writing such query in code, you can use a single datasource with both conditions in WHERE clause (separated by || operator).
Hi
Thanks for your reply.I will look into UNION queries.
But through code I need something like this
(Approved = Yes && TransDate) || (Approved = No && TransDate)
TransDate in both the cases differ.
Regards
Sindhu
Hi sidhu,
If you want your query in && or || condition then probably this site would help you :
http://www.axaptapedia.com/Expressions_in_query_ranges
Vishal Tiwari
