I created the PO ( No - P001) and Posted the Packing Slip .when I click on the purchase order Enquiries it is Showing the Quality Order ? but When I click the Inquiries in the Quarantine order form ( against that PO No) , it is not showing any qualitir oders against that Purchase order ?
Throw some light on this.
The Inquiry form the quarantine order shows quality orders riased AGAINST the quarantine order, your quality order is not against the quarantine order it is against the purchase order, so is only visible there.
That means if the quality order created against that purchase order , then you can not see link between Quarantine order and Quality order . Am I right ?
There is none. If you set the association up to create the quality order from the quarantine order there will be one, otherwise both are linked to teh purchase order, this is the focus, looking from the quarantine order you would not see the quality order as it is not related to the quarantine order, it is the purchase order that holds it.
