Quantity on Hand missing from Item Transaction Detail Report
My problem is that the Item Transaction Detail Report is missing the quantity on hand column. It is empty. It used to have the quantity on hand, but now it doesn’t. Is there a setting or field I didn’t fill out?
Thanks!
Hi, Ivav1000
maybe someone hided this column before. you can check and show the qty. on hand column in section designer.
Sorry, I should have made myself more clear. This is a report, not a section. The column header is showing up correctly. However, the data items are empty.
Nevermind, I figured it out.
