Dear all:
Hope you are doing very well.
I have the following case in AX2012:
When I try to start the production order , the system display the info message related to that there is no enough quantity to be picked from the raw material , but when I view the on-hand in the warehouse I can found the quantities required to complete the production order note that the raw material item is CW item and the item that I want to produce is CW item also.
Please advice
best regards
