I have a small doubt about quality check in navision.
My requirement is after production my client sends the output to inspection area and if some pieces gets rejected he will use those pieces to re process and fine pieces are send to inventory.
Is there any way to get this solution in navision,
Yes and No depending upon the business requirements.
You can add as the final step in the routing the quality check - this means you control what goes into inventory, any rework is against the original order number and costing flows through in this manner.
There is no Quality Order/Quarantine order processing, however there are add-ons that do this I believe.
