Quality association
Hi every body
When kind of reference type is “Inventory” in Quality association, Where and when does the quality order will be generate?
Thanks for your help.
From memory it is set when you create a quality order against a batch/serial number however this is always a manual process so cannot be defined as an association as no process is involved. It is there because it is a valid enum of the field.
