qty must be positive
in my inventjournaltransqty form datasource have field qty
I have to show if the field value negative we have to show the error and do not insert that value
which code I have to write in qty field modified
Hi hareesh,
Put this validation in the InventJournalTrans->Qty->Modified method. put this before call super().
if(this.getValue()<0)
throw error(strFmt("%1 - Value is Negative",this.getValue()));
Use validate() instead of modified() and show a warning and return false if a validation fails.
I have written that code … but again qty accepts the -ve value
Sorry, I can’t comment your code unless you show it.
Please always provide as much information as possible - it will increase your chance to get a helpful answer.
You can write in field validate method as below
if(yourTable.Value < 0)
ret = checkFailed(“The value should not be negative.”);
else
ret = super();
Thanks & Regards,
Britto John Baskar.A
It’s better to run kernel validations (super()) before custom validations. Therefore the usual implementation looks like this:
boolean ret = super();
if (ret)
    if (yourTable.Value < 0)
        ret = checkFailed(...);
return ret;
Hi ,
try with below code
public boolean validate()
boolean ret;
if(yourTable.yourTableField < 0)
else
ret = super();
return ret;
Thanks & Regards,
