Below is our display method, If i remove fields from SGSTPer (highlighted by orange colour) then it works fine but after inserting these extra fields we are facing the problem.
There is no any error occurs, simply executed without any output.
We are follwing below steps for dll file-
- Downloaded file MessagingToolkit.QRCode.dll
- Copied it in client\bin folder
- Added this dll file in the system references
display container qrcode()
Bindata bindata = new Bindata();
Image Imgobj;
System.Drawing.Image img;
System.Drawing.Bitmap obj;
Filepath _path;
container con;
str Qty,InvDate,GRate,NRate,VendCode,GTot,PONo;
MessagingToolkit.QRCode.Codec.QRCodeEncoder encoder = new MessagingToolkit.QRCode.Codec.QRCodeEncoder();
PONo = strDel(_custInvoiceJour.CustRefNo,11,20);
Qty = num2str(_CustInvoiceJour.Qty,2,2,1,0);
InvDate = date2str(_CustInvoiceJour.InvoiceDate,123,2,DateSeparator::Dot,2,DateSeparator::Dot,4,0);
GRate = num2str(_custInvoiceTrans.SalesPrice,2,2,1,0);
GTot = num2str((abs(LineAmount) + abs(_value) + Copy),2,2,1,0);
VendCode = DirOrganizationDetail::find(CustTable::find(_CustInvoicejour.OrderAccount).PartyId).OrgNumber;
NRate = num2str((_CustInvoiceTrans.lineAmountInclTax() / _CustInvoiceTrans.Qty),2,2,1,0);
obj = new System.Drawing.Bitmap(encoder.Encode(PONo+","+“10”+","+Qty+","+_custInvoiceJour.InvoiceId+","+InvDate+","+GRate+","+NRate+","+VendCode+","+_custInvoiceTrans.ItemId+","+CGST+","+SGST+","+“0.00”+","+“0.00”+","+CGSTPer+","+SGSTPer+","+“0.00”+","+“0.00”+","+“0.00”+","+GTot+","+_custInvoiceTrans.HSNCode));
obj.Save(@“C:\temp\newPhoto.bmp”,System.Drawing.Imaging.ImageFormat::get_Bmp());
bindata.loadFile(@“C:\temp\newPhoto.bmp”);
con = bindata.getData();
return con;
Amol
