Put to use date
Can any one help me where to insert Fixed Asset put to use date.?
And how to calculate depreciation from put to use date in AX.
Jainal
Hi Jainal,
In Fixed asset value model, in depreciation group, you can use following:
Depreciation run date: Enter date from which asset will start depreciating.
Placed in service: Date from which depreciation start date is calculated.
Depreciation run date changes after every depr. proposal run. Placed in service remain intact.
I think both the above fields will help you.
Pranav…
