Put Shortcut Dimension on GL used In Structure!!
I am using 2013 R2
in PO PAGE
a structure used in which a GL mapped for Charges and Third Party Payable is TRUE,
on that GL a Shortcut Dimension is mandatory
NOW on PO i have putted Global dimension by Dimension button on header which automatically flowed in line also.
i also putted the shortcut dimension on dimension window but system is not taking shortcut dimension to the Charge GL,
now i am not getting from where i should put dimension for that GL used in Structure.
IN 2009
their was a Button ORDER in which a field Dimension where we can Put Dimension for GL used in structure
Can any 1 please guideā€¦
Thanks!!
Manish
