It is my first post on your site!! [:D] I work with Navision 3.7 and I have a strange situation…
When we post a receipt, a put-away is created. The problem is that sometimes an item on the receipt is not on the put-away document. Example: I have a receipt of three different items, when I post it, the created put-away document contains only 2 items.
Do you have any idea what could cause that an item on a receipt is not on the put-away document?
There’s a field “Always Create Put-away Line” on the Location card - Bin Policies Tab. Check it to have the line always created. If it is not checked the itme will not be on the put-away if the system can’t find a bin for it. If it is checked then the item will be on the put0away but the bin will be blank if the system can’t find a place for the item.
