Put a signature file on a check
Does anyone know how to Put a signature file on a check in Navision 5.0? I cannot find this field from 5.0.
Thanks!
I don’t think there is a standard field for this. You could add in a blob field, import a .bmp into it and print on the check report.
Thanks, can you give me more instructions to show me how to do it? I am quite new to the Navision. Thanks!
Hi
Adding the field is straightforward with type BLOB - choose a related table e.g. bank or user
import the BMP with
IF Signature.IMPORT(’*.BMP’,TRUE) = ‘’ THEN
EXIT;
On the report get the record and don’t forget to calculate the field otherwise to BMP will not show
e.g.
bank.calcfields( signature );
If you look at the company infomation table you will see the logo field “picture” and see how it printed on invoices.
Hope this helps.
