Hi ,
Is it possible to create the purchase requisition against the Procurement category ?
( I can able to create the Purchase order , but not the PR )
Could any one share me the setup what i am missing ?
Thanks in advance.
Hi ,
Thanks in advance.
Yes, it is possible, at least in AX 2012. Check out the documentation.
If you have a problem with it, please explain what exactly doesn’t work, error messages you get or so.
Thanks Martin ,
I have created the Procurement category and same codes are not showing in the PR level and can able to view at the Purchase order level .
What would be the cause ?
Thanks in advance.
Hi Lally,
I guess the “Category access policy rule might have been configured”. Check procurement and sourcing>setup>Policies> Purchasing policies.
Thanks Santosh ,
You mean to say that do i need to configure or not the configure the category access policy rule ?
currently i am testing the test environment and i am the only user , but it is not showing to me also .
what could be the missing setup ?
thanks in advance.
